btmon + influx + grafana help
thesalcedo
Post by thesalcedo » Mon Dec 17, 2018 9:19 pm
Hi all,
I received my GEM last week and I have been playing with trying to capture the data output into Influxdb and graphing it with grafana.
I have btmon.py successfully sending data to a local influxdb instance; here's what btmon.cfg looks like:
[source]
device_type = gem
ip_read = true
ip_host = 192.168.86.35
ip_port = 80
ip_mode = client
include_current = true
reverse_polarity = true
[influxdb]
influxdb_out = true
influxdb_host = localhost
influxdb_port = 8086
influxdb_upload_period = 10
influxdb_database = energyMeter
influxdb_measurement = energy
influxdb_mode = row
influxdb_db_schema = ecmreadext
I can query influxdb and I see data coming in ch32 are my Main CTs:
Questions:
- Does my btmon.cfg configuration look ok? What does everyone else use in their config to make things easier to work with in Influxdb (maps? Keys?)
- If I understand "influxdb_map" correctly, I should add this line to rename the GEM naming of channel 32 Amps to "Main Amps"?:
influxdb_map = serialnumber_ch32_a, MainAmps
- What is "influxdb_tags" used for exactly? How do you use them?
Thanks for the help!
Cheers.
Re: btmon + influx + grafana help
Post by ben » Wed Dec 19, 2018 11:07 am
thesalcedo wrote: - Does my btmon.cfg configuration look ok? What does everyone else use in their config to make things easier to work with in Influxdb (maps? Keys?)
Cheers.
1. IMO, looks fine.
2.
influxdb_map = 1234567_ch1_aws,a,1234567_ch2_aws,b  # renames channels
Looking at the above, you'd use map to bind those fields to names.
3. From what I've read, tags are used for indexed fields. So if you have a field that's going to be queried constantly, you'd want that to be a tag. If the database was built differently, such as:
timestamp, watts, amps, volts, kwh, channel
You'd want channel to be a tag as your query would likely be like:
SELECT * FROM energy WHERE channel = 5;
thesalcedo
Post by thesalcedo » Wed Jan 02, 2019 8:23 am
Thanks Ben!
I think I understand what the different values are, but I need clarification on one specifically:
ch32_a --> Amps
ch32_dwh --> ???
ch32_w --> Watts
ch32_wh --> Watts/Hour
Post by ben » Wed Jan 02, 2019 10:42 am
thesalcedo wrote:Thanks Ben!
ch32_a --> Amps
ch32_dwh --> ???
ch32_w --> Watts
That should be your watt hours used between packets.
Post by ben » Fri Jul 12, 2019 3:26 pm
jerryt wrote:I had this working great, then something broke. Cmd window now states, "InfluxDBClient not loaded".
Anyone help me load the InfluxDBClient ??
Did you re-install Python or switch to a new PC?
Try:
pip install influxdb
In console.
