Add the --print option too to see if the 0s show up there. Trying to figure out whether it's the MQTT processor or the parsing.vespaman wrote: ↑Wed Feb 17, 2021 7:16 amSo here's one from yesterday;Thanks,Code: Select all
oxygen /etc/btmon # /usr/bin/python /etc/btmon/btmon3.py --debug -c /etc/btmon/gem.cfg 2021/02/16 18:48:58 btmon: 3.3.1 2021/02/16 18:48:58 python: 3.8.7 (default, Feb 14 2021, 12:14:26) [GCC 10.2.0] 2021/02/16 18:48:58 platform: linux 2021/02/16 18:48:58 polarity is reversed 2021/02/16 18:48:58 device type: gem 2021/02/16 18:48:58 device list: [''] 2021/02/16 18:48:58 packet format: gem48ptbin 2021/02/16 18:48:58 schema: counters 2021/02/16 18:48:58 buffer size: 120 2021/02/16 18:48:58 SOCKET: timeout: 60 2021/02/16 18:48:58 SOCKET: server host: 10.1.200.7 2021/02/16 18:48:58 SOCKET: server port: 8000 2021/02/16 18:48:58 SOCKET: poll interval: 12 2021/02/16 18:48:58 MQTT: mqtt:localhost:1883?clientid=btmon-gem1 2021/02/16 18:48:58 MQTT: user: <not-specified> 2021/02/16 18:48:58 MQTT: tls: <not-specified> 2021/02/16 18:48:58 MQTT: topic: /house/energy 2021/02/16 18:48:58 MQTT: qos: 0 2021/02/16 18:48:58 MQTT: retain: False 2021/02/16 18:48:58 MQTT: will: <not-specified> 2021/02/16 18:48:58 MQTT: upload period: 12 2021/02/16 18:48:58 MQTT: map: 2021/02/16 18:48:58 packet format is GEM48PTBinaryPacket 2021/02/16 18:48:58 using collector PollingSocketClientCollector 2021/02/16 18:48:58 using 1 processors: 2021/02/16 18:48:58 MQTTProcessor 2021/02/16 18:48:58 setup PollingSocketClientCollector 2021/02/16 18:48:58 setup MQTTProcessor 2021/02/16 18:48:58 SOCKET: waiting for 12 seconds 2021/02/16 18:49:10 opening socket connection to 10.1.200.7:8000 2021/02/16 18:49:10 sending request 1 to device 2021/02/16 18:49:10 SOCKET: sending ^^^APISPK 2021/02/16 18:49:10 waiting for data from device 2021/02/16 18:49:10 reading 1 of 1 packets 2021/02/16 18:49:11 adding buffer for 01000590 2021/02/16 18:49:11 buffering packet ts:1613497751 sn:01000590 2021/02/16 18:49:11 closing socket connection 2021/02/16 18:49:11 buffer info: 2021/02/16 18:49:11 01000590: 1 of 120 (1613497751) 2021/02/16 18:49:11 processing with MQTTProcessor 2021/02/16 18:49:11 not enough data for 01000590 2021/02/16 18:49:11 SOCKET: waiting for 12 seconds 2021/02/16 18:49:23 opening socket connection to 10.1.200.7:8000 2021/02/16 18:49:23 sending request 1 to device 2021/02/16 18:49:23 SOCKET: sending ^^^APISPK 2021/02/16 18:49:23 waiting for data from device 2021/02/16 18:49:23 reading 1 of 1 packets 2021/02/16 18:49:24 buffering packet ts:1613497764 sn:01000590 2021/02/16 18:49:24 closing socket connection 2021/02/16 18:49:24 buffer info: 2021/02/16 18:49:24 01000590: 2 of 120 (1613497764) 2021/02/16 18:49:24 processing with MQTTProcessor 2021/02/16 18:49:24 2 buffered packets sn:01000590 2021/02/16 18:49:24 1 calculated packets sn:01000590 2021/02/16 18:49:24 MQTT: len=71, msgs=[{"topic": "/house/energy/01000590_volts", "payload": 229.7, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_w", "payload": 1158.231, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_w", "payload": 1795.154, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_w", "payload": 1014.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_w", "payload": 36.846, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_w", "payload": 334.769, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_w", "payload": 140.462, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_w", "payload": 47.846, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_w", "payload": 677.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_w", "payload": 9.846, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_w", "payload": 964.692, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_w", "payload": 3.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch24_w", "payload": 103.231, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_w", "payload": 18.385, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_w", "payload": 5.231, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_w", "payload": 653.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_w", "payload": 856.385, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_wh", "payload": 38983126.423, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_wh", "payload": 31072067.837, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_wh", "payload": 21508010.634, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch4_wh", "payload": 1925791.604, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch5_wh", "payload": 226521.929, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch6_wh", "payload": 291194.419, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_wh", "payload": 2473731.378, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch8_wh", "payload": 662055.362, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch9_wh", "payload": -553841.193, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch10_wh", "payload": 49790.834, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_wh", "payload": 11514842.331, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_wh", "payload": 5352073.974, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch13_wh", "payload": 30558.8, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_wh", "payload": 686052.571, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch15_wh", "payload": 254221.222, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_wh", "payload": 12855166.452, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_wh", "payload": 3272632.427, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_wh", "payload": 8470985.594, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch19_wh", "payload": 1927639.411, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch20_wh", "payload": 1101227.07, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch21_wh", "payload": -20762611.861, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_wh", "payload": -11737495.056, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_wh", "payload": 1429365.192, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch24_wh", "payload": 2288746.424, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_wh", "payload": 865967.183, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch26_wh", "payload": 70474.791, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_wh", "payload": 440734.911, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_wh", "payload": 252866.122, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch29_wh", "payload": 477896.755, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_wh", "payload": 14014785.535, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_wh", "payload": 21144033.253, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch32_wh", "payload": 642502.049, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_p4", "payload": 29, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t1", "payload": 26.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t2", "payload": 22.5, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t3", "payload": -2.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t4", "payload": 21.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_dwh", "payload": 4.182, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_dwh", "payload": 6.482, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_dwh", "payload": 3.662, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_dwh", "payload": 0.133, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_dwh", "payload": 1.209, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_dwh", "payload": 0.507, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_dwh", "payload": 0.173, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_dwh", "payload": 2.445, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_dwh", "payload": 0.036, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_dwh", "payload": 3.484, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_dwh", "payload": 0.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_dwh", "payload": 0.011, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch24_dwh", "payload": 0.373, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_dwh", "payload": 0.066, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_dwh", "payload": 0.019, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_dwh", "payload": 2.358, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_dwh", "payload": 3.093, "qos": 0, "retain": false}] 2021/02/16 18:49:24 SOCKET: waiting for 12 seconds 2021/02/16 18:49:36 opening socket connection to 10.1.200.7:8000 2021/02/16 18:49:36 sending request 1 to device 2021/02/16 18:49:36 SOCKET: sending ^^^APISPK 2021/02/16 18:49:36 waiting for data from device 2021/02/16 18:49:36 reading 1 of 1 packets 2021/02/16 18:49:37 buffering packet ts:1613497777 sn:01000590 2021/02/16 18:49:37 closing socket connection 2021/02/16 18:49:37 buffer info: 2021/02/16 18:49:37 01000590: 3 of 120 (1613497777) 2021/02/16 18:49:37 processing with MQTTProcessor 2021/02/16 18:49:37 2 buffered packets sn:01000590 2021/02/16 18:49:37 1 calculated packets sn:01000590 2021/02/16 18:49:37 MQTT: len=71, msgs=[{"topic": "/house/energy/01000590_volts", "payload": 230.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_w", "payload": 1160.308, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_w", "payload": 1793.692, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_w", "payload": 1014.231, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_w", "payload": 36.769, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_w", "payload": 334.769, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_w", "payload": 140.846, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_w", "payload": 48.538, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_w", "payload": 679.462, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_w", "payload": 9.923, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_w", "payload": 961.231, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_w", "payload": 3.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch24_w", "payload": 102.769, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_w", "payload": 18.077, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_w", "payload": 5.154, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_w", "payload": 654.308, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_w", "payload": 855.615, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_wh", "payload": 38983130.613, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_wh", "payload": 31072074.314, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_wh", "payload": 21508014.297, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch4_wh", "payload": 1925791.604, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch5_wh", "payload": 226521.929, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch6_wh", "payload": 291194.419, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_wh", "payload": 2473731.511, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch8_wh", "payload": 662055.362, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch9_wh", "payload": -553841.193, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch10_wh", "payload": 49790.834, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_wh", "payload": 11514843.54, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_wh", "payload": 5352074.482, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch13_wh", "payload": 30558.8, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_wh", "payload": 686052.746, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch15_wh", "payload": 254221.222, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_wh", "payload": 12855168.906, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_wh", "payload": 3272632.462, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_wh", "payload": 8470989.065, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch19_wh", "payload": 1927639.411, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch20_wh", "payload": 1101227.07, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch21_wh", "payload": -20762611.861, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_wh", "payload": -11737495.056, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_wh", "payload": 1429365.203, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch24_wh", "payload": 2288746.796, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_wh", "payload": 865967.249, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch26_wh", "payload": 70474.791, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_wh", "payload": 440734.911, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_wh", "payload": 252866.14, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch29_wh", "payload": 477896.755, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_wh", "payload": 14014787.898, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_wh", "payload": 21144036.343, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch32_wh", "payload": 642502.049, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_p4", "payload": 29, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t1", "payload": 26.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t2", "payload": 22.5, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t3", "payload": -2.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t4", "payload": 21.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_dwh", "payload": 4.19, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_dwh", "payload": 6.477, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_dwh", "payload": 3.663, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_dwh", "payload": 0.133, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_dwh", "payload": 1.209, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_dwh", "payload": 0.509, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_dwh", "payload": 0.175, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_dwh", "payload": 2.454, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_dwh", "payload": 0.036, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_dwh", "payload": 3.471, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_dwh", "payload": 0.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_dwh", "payload": 0.011, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch24_dwh", "payload": 0.371, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_dwh", "payload": 0.065, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_dwh", "payload": 0.019, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_dwh", "payload": 2.363, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_dwh", "payload": 3.09, "qos": 0, "retain": false}] 2021/02/16 18:49:37 SOCKET: waiting for 12 seconds 2021/02/16 18:49:50 opening socket connection to 10.1.200.7:8000 2021/02/16 18:49:50 sending request 1 to device 2021/02/16 18:49:50 SOCKET: sending ^^^APISPK 2021/02/16 18:49:50 waiting for data from device 2021/02/16 18:49:50 reading 1 of 1 packets 2021/02/16 18:49:50 buffering packet ts:1613497790 sn:01000590 2021/02/16 18:49:50 closing socket connection 2021/02/16 18:49:50 buffer info: 2021/02/16 18:49:50 01000590: 4 of 120 (1613497790) 2021/02/16 18:49:50 processing with MQTTProcessor 2021/02/16 18:49:50 2 buffered packets sn:01000590 2021/02/16 18:49:50 1 calculated packets sn:01000590
- Micael
btmon for python 3?
Re: btmon for python 3?
OK, so that was a bit more informative!
oxygen /home/micke # /usr/bin/python /etc/btmon/btmon3.py --debug --print -c /etc/btmon/gem.cfg
2021/02/19 12:00:39 btmon: 3.3.1
2021/02/19 12:00:39 python: 3.8.7 (default, Feb 14 2021, 12:14:26)
[GCC 10.2.0]
2021/02/19 12:00:39 platform: linux
2021/02/19 12:00:39 polarity is reversed
2021/02/19 12:00:39 device type: gem
2021/02/19 12:00:39 device list: ['']
2021/02/19 12:00:39 packet format: gem48ptbin
2021/02/19 12:00:39 schema: counters
2021/02/19 12:00:39 buffer size: 120
2021/02/19 12:00:39 SOCKET: timeout: 60
2021/02/19 12:00:39 SOCKET: server host: 10.1.200.7
2021/02/19 12:00:39 SOCKET: server port: 8000
2021/02/19 12:00:39 SOCKET: poll interval: 12
2021/02/19 12:00:39 MQTT: mqtt:localhost:1883?clientid=btmon-gem1
2021/02/19 12:00:39 MQTT: user: <not-specified>
2021/02/19 12:00:39 MQTT: tls: <not-specified>
2021/02/19 12:00:39 MQTT: topic: /house/energy
2021/02/19 12:00:39 MQTT: qos: 0
2021/02/19 12:00:39 MQTT: retain: False
2021/02/19 12:00:39 MQTT: will: <not-specified>
2021/02/19 12:00:39 MQTT: upload period: 12
2021/02/19 12:00:39 MQTT: map:
2021/02/19 12:00:39 packet format is GEM48PTBinaryPacket
2021/02/19 12:00:39 using collector PollingSocketClientCollector
2021/02/19 12:00:39 using 2 processors:
2021/02/19 12:00:39 PrintProcessor
2021/02/19 12:00:39 MQTTProcessor
2021/02/19 12:00:39 setup PollingSocketClientCollector
2021/02/19 12:00:39 setup PrintProcessor
2021/02/19 12:00:39 setup MQTTProcessor
2021/02/19 12:00:39 SOCKET: waiting for 12 seconds
2021/02/19 12:00:51 opening socket connection to 10.1.200.7:8000
2021/02/19 12:00:51 sending request 1 to device
2021/02/19 12:00:51 SOCKET: sending ^^^APISPK
2021/02/19 12:00:51 waiting for data from device
2021/02/19 12:00:51 reading 1 of 1 packets
2021/02/19 12:00:53 adding buffer for 01000590
2021/02/19 12:00:53 buffering packet ts:1613732453 sn:01000590
2021/02/19 12:00:53 closing socket connection
2021/02/19 12:00:53 buffer info:
2021/02/19 12:00:53 01000590: 1 of 120 (1613732453)
2021/02/19 12:00:53 processing with PrintProcessor
2021/02/19 12:00:53 not enough data for 01000590
2021/02/19 12:00:53 processing with MQTTProcessor
2021/02/19 12:00:53 SOCKET: waiting for 12 seconds
2021/02/19 12:01:05 opening socket connection to 10.1.200.7:8000
2021/02/19 12:01:05 sending request 1 to device
2021/02/19 12:01:05 SOCKET: sending ^^^APISPK
2021/02/19 12:01:05 waiting for data from device
2021/02/19 12:01:05 reading 1 of 1 packets
2021/02/19 12:01:06 buffering packet ts:1613732466 sn:01000590
2021/02/19 12:01:06 closing socket connection
2021/02/19 12:01:06 buffer info:
2021/02/19 12:01:06 01000590: 2 of 120 (1613732466)
2021/02/19 12:01:06 processing with PrintProcessor
2021/02/19 12:01:06 2 buffered packets sn:01000590
2021/02/19 12:01:06 1 calculated packets sn:01000590
2021/02/19 12:01:06: Serial: 01000590
2021/02/19 12:01:06: Voltage: 231.10V
2021/02/19 12:01:06: Ch01: 39053.621514KWh ( 524W)
2021/02/19 12:01:06: Ch02: 31143.183576KWh ( 291W)
2021/02/19 12:01:06: Ch03: 21567.798170KWh ( 609W)
2021/02/19 12:01:06: Ch04: 1925.905572KWh ( 0W)
2021/02/19 12:01:06: Ch05: 227.836178KWh ( 0W)
2021/02/19 12:01:06: Ch06: 291.194419KWh ( 0W)
2021/02/19 12:01:06: Ch07: 2476.425927KWh ( 63W)
2021/02/19 12:01:06: Ch08: 662.055362KWh ( 0W)
2021/02/19 12:01:06: Ch09: -553.841193KWh ( 0W)
2021/02/19 12:01:06: Ch10: 49.790834KWh ( 0W)
2021/02/19 12:01:06: Ch11: 11527.713224KWh ( 99W)
2021/02/19 12:01:06: Ch12: 5356.171292KWh ( 72W)
2021/02/19 12:01:06: Ch13: 30.558800KWh ( 0W)
2021/02/19 12:01:06: Ch14: 687.840532KWh ( 36W)
2021/02/19 12:01:06: Ch15: 254.221222KWh ( 0W)
2021/02/19 12:01:06: Ch16: 12896.054842KWh ( 218W)
2021/02/19 12:01:06: Ch17: 3273.457762KWh ( 10W)
2021/02/19 12:01:06: Ch18: 8487.097628KWh ( 4W)
2021/02/19 12:01:06: Ch19: 1927.741461KWh ( 0W)
2021/02/19 12:01:06: Ch20: 1101.227070KWh ( 0W)
2021/02/19 12:01:06: Ch21: -20762.611861KWh ( 0W)
2021/02/19 12:01:06: Ch22: -11737.166300KWh ( 45W)
2021/02/19 12:01:06: Ch23: 1431.117910KWh ( 3W)
2021/02/19 12:01:06: Ch24: 2291.283080KWh ( 0W)
2021/02/19 12:01:06: Ch25: 867.101324KWh ( 11W)
2021/02/19 12:01:06: Ch26: 70.474791KWh ( 0W)
2021/02/19 12:01:06: Ch27: 440.858266KWh ( 21W)
2021/02/19 12:01:06: Ch28: 254.134179KWh ( 5W)
2021/02/19 12:01:06: Ch29: 477.896755KWh ( 0W)
2021/02/19 12:01:06: Ch30: 14054.701274KWh ( 191W)
2021/02/19 12:01:06: Ch31: 21198.368745KWh ( 454W)
2021/02/19 12:01:06: Ch32: 642.502049KWh ( 0W)
2021/02/19 12:01:06: p1: 0
2021/02/19 12:01:06: p2: 0
2021/02/19 12:01:06: p3: 0
2021/02/19 12:01:06: p4: 29
2021/02/19 12:01:06: t1: 25.500000
2021/02/19 12:01:06: t2: 17.000000
2021/02/19 12:01:06: t3: 2.000000
2021/02/19 12:01:06: t4: 21.000000
2021/02/19 12:01:06: t5: 0.000000
2021/02/19 12:01:06: t6: 0.000000
2021/02/19 12:01:06: t7: 0.000000
2021/02/19 12:01:06: t8: 0.000000
2021/02/19 12:01:06 processing with MQTTProcessor
2021/02/19 12:01:06 MQTT: len=72, msgs=[{"topic": "/house/energy/01000590_volts", "payload": 231.1, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_w", "payload": 524.308, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_w", "payload": 291.538, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_w", "payload": 609.077, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_w", "payload": 63.231, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_w", "payload": 99.923, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_w", "payload": 72.308, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_w", "payload": 36.769, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_w", "payload": 218.462, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_w", "payload": 10.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_w", "payload": 4.769, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_w", "payload": 45.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_w", "payload": 3.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_w", "payload": 11.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_w", "payload": 21.538, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_w", "payload": 5.538, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_w", "payload": 191.077, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_w", "payload": 454.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_wh", "payload": 39053621.514, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_wh", "payload": 31143183.576, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_wh", "payload": 21567798.17, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch4_wh", "payload": 1925905.572, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch5_wh", "payload": 227836.178, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch6_wh", "payload": 291194.419, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_wh", "payload": 2476425.927, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch8_wh", "payload": 662055.362, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch9_wh", "payload": -553841.193, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch10_wh", "payload": 49790.834, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_wh", "payload": 11527713.224, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_wh", "payload": 5356171.292, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch13_wh", "payload": 30558.8, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_wh", "payload": 687840.532, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch15_wh", "payload": 254221.222, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_wh", "payload": 12896054.842, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_wh", "payload": 3273457.762, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_wh", "payload": 8487097.628, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch19_wh", "payload": 1927741.461, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch20_wh", "payload": 1101227.07, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch21_wh", "payload": -20762611.861, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_wh", "payload": -11737166.3, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_wh", "payload": 1431117.91, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch24_wh", "payload": 2291283.08, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_wh", "payload": 867101.324, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch26_wh", "payload": 70474.791, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_wh", "payload": 440858.266, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_wh", "payload": 254134.179, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch29_wh", "payload": 477896.755, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_wh", "payload": 14054701.274, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_wh", "payload": 21198368.745, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch32_wh", "payload": 642502.049, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_p4", "payload": 29, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t1", "payload": 25.5, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t2", "payload": 17.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t3", "payload": 2.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t4", "payload": 21.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_dwh", "payload": 1.893, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_dwh", "payload": 1.053, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_dwh", "payload": 2.199, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_dwh", "payload": 0.228, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_dwh", "payload": 0.361, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_dwh", "payload": 0.261, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_dwh", "payload": 0.133, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_dwh", "payload": 0.789, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_dwh", "payload": 0.036, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_dwh", "payload": 0.017, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_dwh", "payload": 0.162, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_dwh", "payload": 0.011, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_dwh", "payload": 0.04, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_dwh", "payload": 0.078, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_dwh", "payload": 0.02, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_dwh", "payload": 0.69, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_dwh", "payload": 1.639, "qos": 0, "retain": false}]
2021/02/19 12:01:06 SOCKET: waiting for 12 seconds
2021/02/19 12:01:18 opening socket connection to 10.1.200.7:8000
2021/02/19 12:01:18 sending request 1 to device
2021/02/19 12:01:18 SOCKET: sending ^^^APISPK
2021/02/19 12:01:18 waiting for data from device
2021/02/19 12:01:18 reading 1 of 1 packets
2021/02/19 12:01:19 buffering packet ts:1613732479 sn:01000590
2021/02/19 12:01:19 closing socket connection
2021/02/19 12:01:19 buffer info:
2021/02/19 12:01:19 01000590: 3 of 120 (1613732479)
2021/02/19 12:01:19 processing with PrintProcessor
2021/02/19 12:01:19 2 buffered packets sn:01000590
2021/02/19 12:01:19 1 calculated packets sn:01000590
2021/02/19 12:01:19: Serial: 01000590
2021/02/19 12:01:19: Voltage: 230.80V
2021/02/19 12:01:19: Ch01: 39053.623364KWh ( 512W)
2021/02/19 12:01:19: Ch02: 31143.184574KWh ( 276W)
2021/02/19 12:01:19: Ch03: 21567.800325KWh ( 596W)
2021/02/19 12:01:19: Ch04: 1925.905572KWh ( 0W)
2021/02/19 12:01:19: Ch05: 227.836178KWh ( 0W)
2021/02/19 12:01:19: Ch06: 291.194419KWh ( 0W)
2021/02/19 12:01:19: Ch07: 2476.426155KWh ( 63W)
2021/02/19 12:01:19: Ch08: 662.055362KWh ( 0W)
2021/02/19 12:01:19: Ch09: -553.841193KWh ( 0W)
2021/02/19 12:01:19: Ch10: 49.790834KWh ( 0W)
2021/02/19 12:01:19: Ch11: 11527.713588KWh ( 100W)
2021/02/19 12:01:19: Ch12: 5356.171552KWh ( 72W)
2021/02/19 12:01:19: Ch13: 30.558800KWh ( 0W)
2021/02/19 12:01:19: Ch14: 687.840666KWh ( 37W)
2021/02/19 12:01:19: Ch15: 254.221222KWh ( 0W)
2021/02/19 12:01:19: Ch16: 12896.055576KWh ( 203W)
2021/02/19 12:01:19: Ch17: 3273.457798KWh ( 10W)
2021/02/19 12:01:19: Ch18: 8487.097646KWh ( 5W)
2021/02/19 12:01:19: Ch19: 1927.741461KWh ( 0W)
2021/02/19 12:01:19: Ch20: 1101.227070KWh ( 0W)
2021/02/19 12:01:19: Ch21: -20762.611861KWh ( 0W)
2021/02/19 12:01:19: Ch22: -11737.166137KWh ( 45W)
2021/02/19 12:01:19: Ch23: 1431.117921KWh ( 3W)
2021/02/19 12:01:19: Ch24: 2291.283080KWh ( 0W)
2021/02/19 12:01:19: Ch25: 867.101364KWh ( 11W)
2021/02/19 12:01:19: Ch26: 70.474791KWh ( 0W)
2021/02/19 12:01:19: Ch27: 440.858345KWh ( 21W)
2021/02/19 12:01:19: Ch28: 254.134199KWh ( 5W)
2021/02/19 12:01:19: Ch29: 477.896755KWh ( 0W)
2021/02/19 12:01:19: Ch30: 14054.701912KWh ( 176W)
2021/02/19 12:01:19: Ch31: 21198.370340KWh ( 441W)
2021/02/19 12:01:19: Ch32: 642.502049KWh ( 0W)
2021/02/19 12:01:19: p1: 0
2021/02/19 12:01:19: p2: 0
2021/02/19 12:01:19: p3: 0
2021/02/19 12:01:19: p4: 29
2021/02/19 12:01:19: t1: 25.500000
2021/02/19 12:01:19: t2: 17.000000
2021/02/19 12:01:19: t3: 2.000000
2021/02/19 12:01:19: t4: 21.000000
2021/02/19 12:01:19: t5: 0.000000
2021/02/19 12:01:19: t6: 0.000000
2021/02/19 12:01:19: t7: 0.000000
2021/02/19 12:01:19: t8: 0.000000
2021/02/19 12:01:19 processing with MQTTProcessor
2021/02/19 12:01:19 MQTT: len=72, msgs=[{"topic": "/house/energy/01000590_volts", "payload": 230.8, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_w", "payload": 512.231, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_w", "payload": 276.308, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_w", "payload": 596.923, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_w", "payload": 63.077, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_w", "payload": 100.615, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_w", "payload": 72.231, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_w", "payload": 37.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_w", "payload": 203.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_w", "payload": 10.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_w", "payload": 5.077, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_w", "payload": 45.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_w", "payload": 3.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_w", "payload": 11.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_w", "payload": 21.692, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_w", "payload": 5.538, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_w", "payload": 176.462, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_w", "payload": 441.769, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_wh", "payload": 39053623.364, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_wh", "payload": 31143184.574, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_wh", "payload": 21567800.325, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch4_wh", "payload": 1925905.572, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch5_wh", "payload": 227836.178, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch6_wh", "payload": 291194.419, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_wh", "payload": 2476426.155, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch8_wh", "payload": 662055.362, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch9_wh", "payload": -553841.193, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch10_wh", "payload": 49790.834, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_wh", "payload": 11527713.588, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_wh", "payload": 5356171.553, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch13_wh", "payload": 30558.8, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_wh", "payload": 687840.666, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch15_wh", "payload": 254221.222, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_wh", "payload": 12896055.576, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_wh", "payload": 3273457.798, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_wh", "payload": 8487097.646, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch19_wh", "payload": 1927741.461, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch20_wh", "payload": 1101227.07, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch21_wh", "payload": -20762611.861, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_wh", "payload": -11737166.137, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_wh", "payload": 1431117.921, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch24_wh", "payload": 2291283.08, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_wh", "payload": 867101.364, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch26_wh", "payload": 70474.791, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_wh", "payload": 440858.345, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_wh", "payload": 254134.199, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch29_wh", "payload": 477896.755, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_wh", "payload": 14054701.912, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_wh", "payload": 21198370.34, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch32_wh", "payload": 642502.049, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_p4", "payload": 29, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t1", "payload": 25.5, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t2", "payload": 17.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t3", "payload": 2.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t4", "payload": 21.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_dwh", "payload": 1.85, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_dwh", "payload": 0.998, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_dwh", "payload": 2.156, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_dwh", "payload": 0.228, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_dwh", "payload": 0.363, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_dwh", "payload": 0.261, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_dwh", "payload": 0.134, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_dwh", "payload": 0.733, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_dwh", "payload": 0.036, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_dwh", "payload": 0.018, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_dwh", "payload": 0.163, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_dwh", "payload": 0.011, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_dwh", "payload": 0.04, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_dwh", "payload": 0.078, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_dwh", "payload": 0.02, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_dwh", "payload": 0.637, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_dwh", "payload": 1.595, "qos": 0, "retain": false}]
2021/02/19 12:01:19 SOCKET: waiting for 12 seconds
2021/02/19 12:01:31 opening socket connection to 10.1.200.7:8000
2021/02/19 12:01:31 sending request 1 to device
2021/02/19 12:01:31 SOCKET: sending ^^^APISPK
2021/02/19 12:01:31 waiting for data from device
2021/02/19 12:01:31 reading 1 of 1 packets
2021/02/19 12:01:32 buffering packet ts:1613732492 sn:01000590
2021/02/19 12:01:32 closing socket connection
2021/02/19 12:01:32 buffer info:
2021/02/19 12:01:32 01000590: 4 of 120 (1613732492)
2021/02/19 12:01:32 processing with PrintProcessor
2021/02/19 12:01:32 2 buffered packets sn:01000590
2021/02/19 12:01:32 1 calculated packets sn:01000590
2021/02/19 12:01:32: Serial: 01000590
2021/02/19 12:01:32: Voltage: 230.90V
2021/02/19 12:01:32: Ch01: 39053.625196KWh ( 507W)
2021/02/19 12:01:32: Ch02: 31143.185554KWh ( 271W)
2021/02/19 12:01:32: Ch03: 21567.802470KWh ( 593W)
2021/02/19 12:01:32: Ch04: 1925.905572KWh ( 0W)
2021/02/19 12:01:32: Ch05: 227.836178KWh ( 0W)
2021/02/19 12:01:32: Ch06: 291.194419KWh ( 0W)
2021/02/19 12:01:32: Ch07: 2476.426384KWh ( 63W)
2021/02/19 12:01:32: Ch08: 662.055362KWh ( 0W)
2021/02/19 12:01:32: Ch09: -553.841193KWh ( 0W)
2021/02/19 12:01:32: Ch10: 49.790834KWh ( 0W)
2021/02/19 12:01:32: Ch11: 11527.713951KWh ( 100W)
2021/02/19 12:01:32: Ch12: 5356.171815KWh ( 72W)
2021/02/19 12:01:32: Ch13: 30.558800KWh ( 0W)
2021/02/19 12:01:32: Ch14: 687.840800KWh ( 37W)
2021/02/19 12:01:32: Ch15: 254.221222KWh ( 0W)
2021/02/19 12:01:32: Ch16: 12896.056291KWh ( 198W)
2021/02/19 12:01:32: Ch17: 3273.457834KWh ( 10W)
2021/02/19 12:01:32: Ch18: 8487.097665KWh ( 5W)
2021/02/19 12:01:32: Ch19: 1927.741461KWh ( 0W)
2021/02/19 12:01:32: Ch20: 1101.227070KWh ( 0W)
2021/02/19 12:01:32: Ch21: -20762.611861KWh ( 0W)
2021/02/19 12:01:32: Ch22: -11737.165975KWh ( 45W)
2021/02/19 12:01:32: Ch23: 1431.117931KWh ( 3W)
2021/02/19 12:01:32: Ch24: 2291.283080KWh ( 0W)
2021/02/19 12:01:32: Ch25: 867.101404KWh ( 11W)
2021/02/19 12:01:32: Ch26: 70.474791KWh ( 0W)
2021/02/19 12:01:32: Ch27: 440.858421KWh ( 21W)
2021/02/19 12:01:32: Ch28: 254.134218KWh ( 5W)
2021/02/19 12:01:32: Ch29: 477.896755KWh ( 0W)
2021/02/19 12:01:32: Ch30: 14054.702520KWh ( 168W)
2021/02/19 12:01:32: Ch31: 21198.371929KWh ( 440W)
2021/02/19 12:01:32: Ch32: 642.502049KWh ( 0W)
2021/02/19 12:01:32: p1: 0
2021/02/19 12:01:32: p2: 0
2021/02/19 12:01:32: p3: 0
2021/02/19 12:01:32: p4: 29
2021/02/19 12:01:32: t1: 25.500000
2021/02/19 12:01:32: t2: 17.000000
2021/02/19 12:01:32: t3: 2.000000
2021/02/19 12:01:32: t4: 21.000000
2021/02/19 12:01:32: t5: 0.000000
2021/02/19 12:01:32: t6: 0.000000
2021/02/19 12:01:32: t7: 0.000000
2021/02/19 12:01:32: t8: 0.000000
2021/02/19 12:01:32 processing with MQTTProcessor
2021/02/19 12:01:32 MQTT: len=72, msgs=[{"topic": "/house/energy/01000590_volts", "payload": 230.9, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_w", "payload": 507.462, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_w", "payload": 271.538, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_w", "payload": 593.846, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_w", "payload": 63.462, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_w", "payload": 100.538, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_w", "payload": 72.769, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_w", "payload": 37.077, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_w", "payload": 198.077, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_w", "payload": 10.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_w", "payload": 5.231, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_w", "payload": 45.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_w", "payload": 3.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_w", "payload": 11.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_w", "payload": 21.154, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_w", "payload": 5.231, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_w", "payload": 168.462, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_w", "payload": 440.077, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_wh", "payload": 39053625.196, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_wh", "payload": 31143185.554, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_wh", "payload": 21567802.47, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch4_wh", "payload": 1925905.572, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch5_wh", "payload": 227836.178, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch6_wh", "payload": 291194.419, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_wh", "payload": 2476426.384, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch8_wh", "payload": 662055.362, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch9_wh", "payload": -553841.193, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch10_wh", "payload": 49790.834, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_wh", "payload": 11527713.951, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_wh", "payload": 5356171.815, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch13_wh", "payload": 30558.8, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_wh", "payload": 687840.8, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch15_wh", "payload": 254221.222, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_wh", "payload": 12896056.291, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_wh", "payload": 3273457.834, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_wh", "payload": 8487097.665, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch19_wh", "payload": 1927741.461, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch20_wh", "payload": 1101227.07, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch21_wh", "payload": -20762611.861, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_wh", "payload": -11737165.975, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_wh", "payload": 1431117.931, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch24_wh", "payload": 2291283.08, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_wh", "payload": 867101.404, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch26_wh", "payload": 70474.791, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_wh", "payload": 440858.421, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_wh", "payload": 254134.217, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch29_wh", "payload": 477896.755, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_wh", "payload": 14054702.52, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_wh", "payload": 21198371.929, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch32_wh", "payload": 642502.049, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_p4", "payload": 29, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t1", "payload": 25.5, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t2", "payload": 17.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t3", "payload": 2.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_t4", "payload": 21.0, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch1_dwh", "payload": 1.833, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch2_dwh", "payload": 0.981, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch3_dwh", "payload": 2.144, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch7_dwh", "payload": 0.229, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch11_dwh", "payload": 0.363, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch12_dwh", "payload": 0.263, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch14_dwh", "payload": 0.134, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch16_dwh", "payload": 0.715, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch17_dwh", "payload": 0.036, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch18_dwh", "payload": 0.019, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch22_dwh", "payload": 0.162, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch23_dwh", "payload": 0.011, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch25_dwh", "payload": 0.04, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch27_dwh", "payload": 0.076, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch28_dwh", "payload": 0.019, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch30_dwh", "payload": 0.608, "qos": 0, "retain": false}, {"topic": "/house/energy/01000590_ch31_dwh", "payload": 1.589, "qos": 0, "retain": false}]
2021/02/19 12:01:32 SOCKET: waiting for 12 seconds
^C2021/02/19 12:01:33 cleanup PrintProcessor
2021/02/19 12:01:33 cleanup MQTTProcessor
2021/02/19 12:01:33 cleanup PollingSocketClientCollector
oxygen /home/micke # ^C
Also, it looks suspicious with the negative KWh values here and there. but maybe this is only a debug print issue?
Polarity issue, you can check the GEM settings to see if you have any polarity toggles under Channel Option.
Line 4196:
if not payload:
if payload is not None:
So I tried your suggestion a couple of days ago, not giving it much thought. Then after a couple of days, I realized that a few rules in my openhab setup did not run properly. Turns out that the last change made both my GEMs muted. No data arrived at all.
I changed in the following section (was 2 rows off from your last version vs your suggestion)
Should it perhaps be "if payload is None" instead?
def _add_msg(self, packet, channel, payload):
return
key = mklabel(packet['serial'], channel)
Yeah, sorry. It should be "if payload == None:". "If not" was inclusive of 0.vespaman wrote: ↑Sat Feb 27, 2021 1:25 pmSo I tried your suggestion a couple of days ago, not giving it much thought. Then after a couple of days, I realized that a few rules in my openhab setup did not run properly. Turns out that the last change made both my GEMs muted. No data arrived at all.
I changed in the following section (was 2 rows off from your last version vs your suggestion)Should it perhaps be "if payload is None" instead?Code: Select all
def _add_msg(self, packet, channel, payload): if payload is not None: return key = mklabel(packet['serial'], channel)
So, just to close;
I have now been running with the last changes for about 20 days without any issues at all.
Thanks Ben for fixing it!
- Micael
- Micael
Is this the fork that works with python3?
https://github.com/BenK22/mtools/
Can it be updated to reflect that? It still says it does not work with Python3. Great job!
Cheers!
Cheers!
It's in the InfluxDB branch here as that's the copy I've been working off of: https://github.com/BenK22/mtools/tree/influxdb/binthesalcedo wrote: ↑Wed Mar 24, 2021 7:23 amIs this the fork that works with python3?
Cheers!
I've got the btmon script for python3 up and running, with one issue: all of my Watts measurements are 0. The Watt Hours measurements seem to come in fine. What information would be useful for troubleshooting?
EDIT:
So, I've done some more sleuthing and it really looks like btmon is not sending the Watts measurements to InfluxDB.
I see the measurements coming from btmon fine:
2021/05/13 13:40:51: Voltage: 119.20V
2021/05/13 13:40:51: Ch01: 81972.869791KWh ( 1070W)
Note that Channel 1 is my entire panel, so there is always some load there.
But Watts are not getting sent to InfluxDB (this is from a packet capture):
energy,gemlocation=main_panel,host=gem.home XXX338_volts=119.4 1620926627000000000
energy,gemlocation=main_panel,host=gem.home XXX338_ch1_aws=295101134484.0 1620926627000000000
energy,gemlocation=main_panel,host=gem.home XXX338_ch1_pws=0.0 1620926627000000000
END EDIT:
My Config:
Old Monitoring Setup (works fine)
btmon 3.1.1
2021/05/13 12:04:49 python: 2.7.18 (default, Feb 25 2021, 01:19:10)
[GCC FreeBSD Clang 10.0.1 (git@github.com:llvm/llvm-project.git llvmorg-10.0.1-
2021/05/13 12:04:49 platform: freebsd12
2021/05/13 12:04:49 polarity is reversed
2021/05/13 12:04:49 device type: gem
2021/05/13 12:04:49 device list: ['']
2021/05/13 12:04:49 packet format: gem48ptbin
2021/05/13 12:04:49 schema: counters
2021/05/13 12:04:49 SOCKET: timeout: 15
2021/05/13 12:04:49 SOCKET: server host: 172.16.100.137
2021/05/13 12:04:49 SOCKET: server port: 8000
2021/05/13 12:04:49 OEM: upload period: 1
2021/05/13 12:04:49 OEM: timeout: 15
2021/05/13 12:04:49 OEM: url: http://localhost/emoncms/input/post.json
2021/05/13 12:04:49 OEM: token: xxxx
2021/05/13 12:04:49 OEM: node: 20
New Monitoring Setup (works, but all Watts measurements are 0):
2021/05/13 12:03:35 btmon: 4.0.0
2021/05/13 12:03:35 python: 3.8.5 (default, Jan 27 2021, 15:41:15)
[GCC 9.3.0]
2021/05/13 12:03:35 platform: linux
2021/05/13 12:03:35 polarity is reversed
2021/05/13 12:03:35 device type: gem
2021/05/13 12:03:35 device list: ['']
2021/05/13 12:03:35 packet format: gem48ptbin
2021/05/13 12:03:35 schema: counters
2021/05/13 12:03:35 SOCKET: timeout: 60
2021/05/13 12:03:35 SOCKET: server host: 172.16.100.137
2021/05/13 12:03:35 SOCKET: server port: 8000
2021/05/13 12:03:35 InfluxDB: upload period: 10
2021/05/13 12:03:35 InfluxDB: host: localhost
2021/05/13 12:03:35 InfluxDB: port: 8086
2021/05/13 12:03:35 InfluxDB: username: btmon
2021/05/13 12:03:35 InfluxDB: map:
2021/05/13 12:03:35 InfluxDB: schema: counters
Config for new setup:
[source]
device_type = gem
ip_read = true
ip_host = 172.16.100.137
ip_port = 8000
ip_mode = client
reverse_polarity = 1
[influxdb]
influxdb_out = true
influxdb_host = localhost
influxdb_port = 8086
influxdb_upload_period = 10
influxdb_username = xxxxx
influxdb_password = xxxxx
influxdb_database = btmon_greeneye
influxdb_measurement = energy
influxdb_mode = row
influxdb_tags = host,gem.home,gemlocation,main_panel
influxdb_db_schema = counters
EDIT:
END EDIT:
My Config:
btmon 3.1.1
[GCC 9.3.0]
[source]
device_type = gem
ip_read = true
ip_port = 8000
ip_mode = client
[influxdb]
influxdb_out = true
influxdb_mode = row
