btmon for python 3?
vespaman
btmon for python 3?
Post by vespaman » Sun Nov 29, 2020 11:16 am
Has anyone done or seen a updated btmon that works with python 3? I am updating my server, and of course 2.7 is no longer with us..
Re: btmon for python 3?
Post by ben » Mon Nov 30, 2020 11:36 am
Try the attached conversion to see if it works. Report back any errors.
EDIT: Attached a new copy.
btmon3.zip
(41.43 KiB) Downloaded 546 times
vespaman
Post by vespaman » Mon Dec 28, 2020 2:12 pm
So, finally, I had some time to test btmon3.
It has some issues, that I fixed (configparser issue and I also removed "options.ip_poll_interval > 0" check).
After this, I get no errors, it starts up and prints the same stuff that I get on the 2.7 version on my old server, but it does not work. Not sure why. Only thing I know, is that it never sends anything to the broker.
Is there any prefered way to debug this?
Post by ben » Tue Dec 29, 2020 12:13 pm
Does it show packets being processed?
Does the MQTT settings show up when you start the script?
vespaman
Post by vespaman » Wed Dec 30, 2020 8:14 am
No, I don't think any packets are processed, this is probably where it fails. Here's a sample output:
oxygen /etc/btmon # /usr/bin/python /etc/btmon/btmon3.py -c /etc/btmon/gem2.cfg
2020/12/30 14:10:38 btmon: 3.3.1
2020/12/30 14:10:38 python: 3.8.7 (default, Dec 25 2020, 16:06:21)
[GCC 10.2.0]
2020/12/30 14:10:38 platform: linux
2020/12/30 14:10:38 polarity is reversed
2020/12/30 14:10:38 device type: gem
2020/12/30 14:10:38 device list: ['']
2020/12/30 14:10:38 packet format: gem48ptbin
2020/12/30 14:10:38 schema: counters
2020/12/30 14:10:38 SOCKET: timeout: 60
2020/12/30 14:10:38 SOCKET: server host: 10.1.200.11
2020/12/30 14:10:38 SOCKET: server port: 8000
2020/12/30 14:10:38 SOCKET: poll interval: 12
2020/12/30 14:10:38 MQTT: mqtt:localhost:1883?clientid=btmon-gem2
2020/12/30 14:10:38 MQTT: user: <not-specified>
2020/12/30 14:10:38 MQTT: tls: <not-specified>
2020/12/30 14:10:38 MQTT: topic: /house/energy
2020/12/30 14:10:38 MQTT: qos: 0
2020/12/30 14:10:38 MQTT: retain: False
2020/12/30 14:10:38 MQTT: will: <not-specified>
2020/12/30 14:10:38 MQTT: upload period: 12
2020/12/30 14:10:38 MQTT: map:
2020/12/30 14:10:51 a bytes-like object is required, not 'str'
2020/12/30 14:10:51 3 requests failed for device
The last four lines are repeated for each call to the gem. (every 12'th second), (for some reason I did not see them the last time I test, maybe I did not wait enougth time). I don't really know where this is done in the code, I have tried to 'breakpoint()' here and there, but without finding the actual place where the gem polling is done.
Post by ben » Wed Dec 30, 2020 4:06 pm
[GCC 10.2.0]
Line 1501, try changing :
    def requestpacket(self, com, gemid=''):
        idstr = ''
        if len(gemid) > 0:
            idstr = 'NMB%s' % gemid
        com.send('^^^%sAPISPK' % idstr)
to:
        idstr = ''
        if len(gemid) > 0:
        output = '^^^%sAPISPK' % idstr
        com.sendall(output.encode('utf-8'))
vespaman
Post by vespaman » Fri Jan 01, 2021 6:36 am
So, after doing that, I get these outputs instead (repeated for each poll);
2021/01/01 12:33:08 'PollingSocketClientCollector' object has no attribute 'sendall'
2021/01/01 12:33:08 'PollingSocketClientCollector' object has no attribute 'sendall'2021/01/01 12:33:08 'PollingSocketClientCollector' object has no attribute 'sendall'
2021/01/01 12:33:08 3 requests failed for device
Post by ben » Mon Jan 04, 2021 1:33 pm
Revert it to send. Thought that was a direct reference to a socket but the socket is located within the ClientCollector.
vespaman
Post by vespaman » Thu Jan 07, 2021 11:13 am
OK, so changing into send, gives me;
2021/01/07 17:01:00 can only concatenate str (not "bytes") to str
2021/01/07 17:01:00 3 requests failed for device
I don't think this happens at the same place though.
Sorry for being so clueless with python...
Post by ben » Thu Jan 07, 2021 1:08 pm
NP, attach your config file (feel free to remove your serial number, etc) and I'll try running it.
