Power calculation
owensca19
Power calculation
Post by owensca19 » Thu Jan 14, 2021 10:25 am
I'm getting data from the GEM and saving it to an influxdb with btmon.
How are amps and watts calculated?
Looking at the data for channel 3 I have .24 amps and 30.2 watts at 121.2 volts
I would expect 29.088 watts. Why is it 30.2?
Here's my config and data
[source]
ip_read = true
device_type = gem
ip_host = 172.28.0.17
ip_port = 8000
ip_mode = client
include_current = true
reverse_polarity = true
[influxdb]
influxdb_out = true
influxdb_host = localhost
influxdb_port = 8086
influxdb_db_schema = ecmread
influxdb_upload_period = 30
influxdb_mode = col
influxdb_username = *****
influxdb_password = *****
influxdb_database = ecmread
influxdb_measurement = energy
1610636662000000000 ch10_a XXX155 0
1610636662000000000 ch10_w XXX155 -0
1610636662000000000 ch11_a XXX155 0
1610636662000000000 ch11_w XXX155 -0
1610636662000000000 ch12_a XXX155 0
1610636662000000000 ch12_w XXX155 -0
1610636662000000000 ch13_a XXX155 0
1610636662000000000 ch13_w XXX155 -0
1610636662000000000 ch14_a XXX155 0
1610636662000000000 ch14_w XXX155 -0
1610636662000000000 ch15_a XXX155 0
1610636662000000000 ch15_w XXX155 0.2
1610636662000000000 ch16_a XXX155 0
1610636662000000000 ch16_w XXX155 -0
1610636662000000000 ch17_a XXX155 0
1610636662000000000 ch17_w XXX155 -0
1610636662000000000 ch18_a XXX155 0
1610636662000000000 ch18_w XXX155 -0
1610636662000000000 ch19_a XXX155 0
1610636662000000000 ch19_w XXX155 -0
1610636662000000000 ch1_a  XXX155 0
1610636662000000000 ch1_w  XXX155 -0
1610636662000000000 ch20_a XXX155 0
1610636662000000000 ch20_w XXX155 -0
1610636662000000000 ch21_a XXX155 1.5
1610636662000000000 ch21_w XXX155 142.76666666666668
1610636662000000000 ch22_a XXX155 0.16
1610636662000000000 ch22_w XXX155 13.066666666666666
1610636662000000000 ch23_a XXX155 0.3
1610636662000000000 ch23_w XXX155 24
1610636662000000000 ch24_a XXX155 0.2
1610636662000000000 ch24_w XXX155 14
1610636662000000000 ch25_a XXX155 1.3
1610636662000000000 ch25_w XXX155 136.8
1610636662000000000 ch26_a XXX155 3.68
1610636662000000000 ch26_w XXX155 359.06666666666666
1610636662000000000 ch27_a XXX155 0
1610636662000000000 ch27_w XXX155 2
1610636662000000000 ch28_a XXX155 0
1610636662000000000 ch28_w XXX155 -0
1610636662000000000 ch29_a XXX155 0
1610636662000000000 ch29_w XXX155 -0
1610636662000000000 ch2_a  XXX155 0
1610636662000000000 ch2_w  XXX155 -0
1610636662000000000 ch30_a XXX155 0
1610636662000000000 ch30_w XXX155 -0
1610636662000000000 ch31_a XXX155 0
1610636662000000000 ch31_w XXX155 -0
1610636662000000000 ch32_a XXX155 0
1610636662000000000 ch32_w XXX155 -0
1610636662000000000 ch3_a  XXX155 0.24
1610636662000000000 ch3_w  XXX155 30.2
1610636662000000000 ch4_a  XXX155 0
1610636662000000000 ch4_w  XXX155 -0
1610636662000000000 ch5_a  XXX155 0.1
1610636662000000000 ch5_w  XXX155 7.2
1610636662000000000 ch6_a  XXX155 0
1610636662000000000 ch6_w  XXX155 -0
1610636662000000000 ch7_a  XXX155 0
1610636662000000000 ch7_w  XXX155 -0
1610636662000000000 ch8_a  XXX155 0
1610636662000000000 ch8_w  XXX155 0.5333333333333333
1610636662000000000 ch9_a  XXX155 0
1610636662000000000 ch9_w  XXX155 -0
1610636662000000000 volts  XXX155 121.2
Re: Power calculation
Post by ben » Thu Jan 14, 2021 1:41 pm
Is this being monitored with a Micro-40?
Error is likely when you go below 1A. +-1W is very good given how low the amperage is.
owensca19
Post by owensca19 » Fri Jan 15, 2021 8:53 am
I'm using the Micro-80
The error gets larger with higher amps, channel 26 recorded 3.68 amp and 359.066 watts but should be 446.016 amps
I also get the same readings when saving to mysql.
Which value would be the most accurate for calculating Kwh, the amps or the watts?
Post by ben » Fri Jan 15, 2021 10:12 am
VA won't be accurate at all due to power factor. What are you monitoring with that channel?
359W could be right as around 80% of VA is pretty common due to power factor.
Do you have any outlets being monitored? If so, try plugging in a purely resistive load like a old-school lightbulb (60W), hair dryer, toaster, etc. VA should be within 1% of Watts in that case.
owensca19
Post by owensca19 » Fri Jan 15, 2021 12:14 pm
Thanks for the help Ben. Using the hair dryer did indeed put the VA within the 1%
Post by ben » Fri Jan 15, 2021 12:26 pm
NP. If you have any circuits that tend to be lower amperage, you can try reducing the CT Type by 1 if it's reading too high on average (or increasing it by 1 if it's reading too low).
