The changes were to do with accepting binary packets via 8001/8002 so they can be packet forwarded. They should be in this update here: http://brultech.com/software/files/down ... 2_4c9a.img
Home Assistant with 3 GEMs and a 1240
Re: Home Assistant with 3 GEMs and a 1240
I'm trying to get my system setup with HA as well. Did you ever figure out how to connect a GEM to dashbox over ethernet and have dashbox forward to HA?
I have this version available for testing:
https://drive.google.com/file/d/1pdG2yuGm-G0Uj7LqDg8P2ZTqeBSKsxt5/view?usp=sharing
It allows you to add command/responses to packet forwarding. HA requires ^^^RQSALL to get a response back. So you'll have to manually issue it for a GEM, get the response, and paste it in there.
Also you have to send Bin-32-Net to Port 8001 or 8002 on the DashBox so it records the binary packet.
Ben,ben wrote: ↑Mon Jun 05, 2023 10:05 amI have this version available for testing:(4.2.4c17)Code: Select all
I have 2 Gems feeding data to Dashbox via Ethernet, Gem has Primary Packet Format to 3: HTTP Get and Secondary 0: Disabled. I would like to be either have the Gem send data to both if possible or have Dashbox send data to Home Assistant.
I am on Dashbox 4.2.4c17g, It looks like the 'add command' is available under 'Pack Forward', can you confirm exactly what is needed in there for Dashbox to forward Data on to Home Assistant? I don't understand what 'So you'll have to manually issue it for a GEM, get the response, and paste it in there.' means.
what exactly is meant by HA requires... so you'll have to manually issue it for a GEM, get the response, and paste it in there? I think I have to past something into the add command section. but what?ben wrote: ↑Mon Jun 05, 2023 10:05 amI have this version available for testing:(4.2.4c17)Code: Select all
Newest version via HACS no longer has this requirement. Should work fine with binary packet forwarding.agr077 wrote: ↑Wed Nov 15, 2023 11:55 pmwhat exactly is meant by HA requires... so you'll have to manually issue it for a GEM, get the response, and paste it in there? I think I have to past something into the add command section. but what?ben wrote: ↑Mon Jun 05, 2023 10:05 amI have this version available for testing:(4.2.4c17)Code: Select all
Thank you Ben, working well since your guidance! Maybe this will help someone else:ben wrote: ↑Thu Nov 16, 2023 10:31 amNewest version via HACS no longer has this requirement. Should work fine with binary packet forwarding.agr077 wrote: ↑Wed Nov 15, 2023 11:55 pmwhat exactly is meant by HA requires... so you'll have to manually issue it for a GEM, get the response, and paste it in there? I think I have to past something into the add command section. but what?ben wrote: ↑Mon Jun 05, 2023 10:05 am
For my setup (GEM1 + GEM2 sending to Dashbox over network) I changed the Gem primary packet send to Bin-32-Net and on the network tab on Gem1 I have the IP host set to the dashbox and port 8001 and Gem2 is the same but port 8002. Packet Forward on the Dashbox is setup up to send both gem devices to the HA IP on port 8000.
The 'GreenEye Monitor (GEM) Custom Integration' (https://github.com/jkeljo/hacs-greeneye-monitor) was installed and configured to listen on port 8000 and automatically discovered both Gems.
I've tried for hours to get this exact same configuration working and every time I set the primary packet type as suggested here to Bin-32-Net the Dashbox doesnt recognize the packets anymore and the GEMs go inactive on the dashbox. Changing back to HTTP GET causes the GEMs to become active again. How did you get the dashbox to accept the Bin-32-Net packets that it then was able to forward on to HA?jkosharek wrote: ↑Thu Nov 16, 2023 11:05 amThank you Ben, working well since your guidance! Maybe this will help someone else:
Switch the port the GEM is sending to from 80 to 8001/8002 and it should work assuming you're running 4.2.4c17 or newer.b0sSt0n wrote: ↑Mon May 06, 2024 8:51 pmI've tried for hours to get this exact same configuration working and every time I set the primary packet type as suggested here to Bin-32-Net the Dashbox doesnt recognize the packets anymore and the GEMs go inactive on the dashbox. Changing back to HTTP GET causes the GEMs to become active again. How did you get the dashbox to accept the Bin-32-Net packets that it then was able to forward on to HA?jkosharek wrote: ↑Thu Nov 16, 2023 11:05 amThank you Ben, working well since your guidance! Maybe this will help someone else:
Mine is running on 8001 and 8002. I have been feeding data in to Home Assistant for 6 month flawlessly!
