Support for 50Hz European Grid
linus
Post by linus » Thu Sep 30, 2010 5:28 am
I found the product very exciting. Are the European power line standard supported (50Hz 220-240VAC single phase and 50 Hz 380-400VAC 3 phase)?
Thank you
Linus
Re: Support for 50Hz European Grid
Post by ben » Mon Oct 04, 2010 10:41 am
Hey Linus,
We do not currently support 50Hz.
roscoe
Post by roscoe » Mon Oct 04, 2010 6:01 pm
admin wrote:Hey Linus,
Really ?
Are you sure!
Mine is 50Hz and whilst you may not be front of the queue for the latest firmware (which is not an issue). It works and I have received very good support specific to 50Hz.
Just remember not to download and install web site 'stock' 60Hz firmware, apart from than that 50Hz is fine and dandy. Can't really see an issue for the 3ph combo, although best to ask again to someone 'official'.
Post by ben » Wed Oct 06, 2010 10:38 am
Really ?
Are you sure!
We don't officially support it yet as it requires special configuration. But, we were able to find a few 50 Hz units in our stock.
I'll send Linus an email.
linus
Post by linus » Mon Oct 11, 2010 2:40 am
I continued to investigate on the general matter and specific 50Hz support but
if I gained a superficial understanding of the product and related sw suite (also if pick
up the right techinfo is not always easy navigating the site) same I can't say about 50Hz support.
I understood (thank you Roscoe) that the previous sw was supporting 50Hz and it worked fine but it seems is no longer true with last versions. Can you confirm 50Hz support is not a matter of hardware? What other problems I will be facing?
Furthermore as general question how is performed the voltage sensing? Can you better explain how to support 3 phase circuits?
The real problem is that I wasn't able to locate manuals, programming guide and other technical documentation. Probably it's my fault, sorry for that. Let me know if is that available only as post-sale assistance.
Thank you all for the support
Regards
Lino
Post by ben » Wed Oct 13, 2010 12:17 pm
Hey Linus,
The 50 Hz setup requires different hardware and firmware, we have a couple in stock.
We don't officially support 3 phase yet, but there are ways of monitoring 3 phase systems with 3 ECM-1240s http://www.etherbee.com/images/ECM-1240%203%20phase.png. With 50 Hz, 3 phase line-to-line voltage is in the area of 400V, our CTs are only rated for 300V.
dpicheo
Post by dpicheo » Sun Oct 17, 2010 5:22 pm
I'm interested too to the 50Hz version of the product!
You speak about a different hardware and firmware:
is it an older/different model or a special flavour of the latest one?
I'd need 20/30 pieces: can you produce 50Hz versions in "volume"?
Do you think to officially support European Model in a near future?
Thank you in advance!
paulb
Post by paulb » Wed Oct 20, 2010 11:36 am
dpicheo wrote:I'm interested too to the 50Hz version of the product!
The firmware for 50Hz is essentially the same, the difference being some of the timing variables and calibration constants being different.
A far as volume sales to Europe, we do not plan on it at this time. We can supply small batches (20/30) pcs.
linus
Post by linus » Tue Oct 26, 2010 5:04 pm
Hi Paul,
I would like to proceed buying a sample. I was thinking to buy a couple of PP1-100 PLUG & PLAY PACKAGE for 50Hz 220V use. What part number exactly I have to order?
Best regards
Linus
Post by ben » Wed Oct 27, 2010 9:41 am
linus wrote:Hi Paul,
Best regards
Linus
Send an email to sales(at)brultech.com and Tammy will help you with your order.
