Just thought I'd post my new Dryer Done Notification program...
Works SO far, so use as a test, and let me know...
It uses variables pushed from the BrultTech GEM to ISY...
(Any feedback also welcome, if you see problems)...
(I know it might not cover 100% cases, but 80/20 rules should apply)...
/Fred
P.S.
It has two programs, one sets a variable, other runs when power is off AND variable is SET.
Then 2nd program RESETS the variable...
DryerDonePt1 - [ID 000D][Parent 0001]
If
$s.Dash_Box_Dryer_32 > 500
Then
Wait 10 minutes
$s.DryerDone = 1
Else
- No Actions - (To add one, press 'Action')
DryerDonePt2 - [ID 005A][Parent 0001]
If
$s.Dash_Box_Dryer_32 < 500
And $s.DryerDone is 1
Then
Send Notification to 'FredCJohnston-ONLY' content 'DryerDone'
Send Notification to 'Ingrids' content 'DryerDone'
$s.DryerDone = 0
Set 'ZW 004 Siren' On
Wait 3 seconds
Wait 3 seconds
Else
Re: Dryer Done Notification
This may not work as every time the power state variable gets changed to a different number, the program will be re-run. Or, if like me, your DashBox never updated your ISY reliably so it appeared to work sometimes. So unless your dryer uses *exactly* the same wattage for 10 minutes (not likely), it will never trigger the variable change.
Also, if yours is a high efficiency dryer, it probably doesn't maintain a high wattage for that long. Mine fluctuates between 150 and 5400 watts on a minute by minute basis. If yours does that you'll need an extra scripts to detect the start.
Try this method below. Add a new state variable, in my case $energy.notify.fridge.long_runtime
Program: Kitchen Fridge Long Runtime 2 Hour.test
Program: Kitchen Fridge Long Runtime 2 Hour.notification
Kitchen Fridge Long Runtime 2 Hour.test - [ID 0023][Parent 0066]
If
$gem.fridge > 100
Then
$energy.notify.fridge.long_runtime = 1
Else
$energy.notify.fridge.long_runtime = 0
Kitchen Fridge Long Runtime 2 Hour.notification - [ID 0070][Parent 0066]
If
$energy.notify.fridge.long_runtime is 1
Then
Wait 2 hours
Send Notification to 'xxx'
Else
I've had my system monitor and alert me of every aspect of my homes electrical system for years. Here is some feedback which may help some of you in this endeavor to accomplish the very same.
- Use the Dash Box (DB) to let you know the lowest power consumption once the system is in a idle state. This is what you will program for to know when the cycle is done opposed to just in a paused state.
- Ensure a wait time is included into the program to avoid false trips of the program. There is no need to use wait times exceeding several minutes as this defeats the purpose of real time monitoring and alert notification. If your using long wait times the energy levels you have defined are wrong and its simply a band aid which when line voltage changes will throw you off.
- If people are seeing delays in programs executing there are communications, program logic, connectivity related issues present.
j0dan wrote:This may not work as every time the power state variable gets changed to a different number, the program will be re-run. Or, if like me, your DashBox never updated your ISY reliably so it appeared to work sometimes. So unless your dryer uses *exactly* the same wattage for 10 minutes (not likely), it will never trigger the variable change.
Program: Kitchen Fridge Long Runtime 2 Hour.testProgram: Kitchen Fridge Long Runtime 2 Hour.notificationCode: Select all
Kitchen Fridge Long Runtime 2 Hour.test - [ID 0023][Parent 0066] If $gem.fridge > 100 Then $energy.notify.fridge.long_runtime = 1 Else $energy.notify.fridge.long_runtime = 0
Kitchen Fridge Long Runtime 2 Hour.notification - [ID 0070][Parent 0066] If $energy.notify.fridge.long_runtime is 1 Then Wait 2 hours Send Notification to 'xxx' Else - No Actions - (To add one, press 'Action')
I agree, it could be a bit problematic...
I made a couple of changes, and it works (so far!)
If
$s.Dash_Box_Dryer_32 > 100
Then
$s.DryerDone = 1
Else
If
$s.Dash_Box_Dryer_32 < 100
Then
$s.DryerDone = 0
Wait 3 seconds
Wait 3 seconds
Else
