Last visit was: It is currently Tue Feb 20, 2018 7:54 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: Mapping existing outlets to circuits
PostPosted: Sun Apr 03, 2011 10:11 am
Registered users
Hi all,
I'm just beginning my monitoring project.
I'm thinking my first step should be to make a map of my circuits in my home so I know what loads are on which circuits.
The only method I have to do this would be to turn off all circuits, then turn on one circuit only, walk about the house with a plug tester and see which plugs are live, then chart the results so I end up with a map of outlets and circuits.
I'm wondering if there are any steps I can take to make this go more easily and accurately and how other people have done this preparatory step.
Top
Offline Profile
 Post subject: Re: Mapping existing outlets to circuits
PostPosted: Mon Apr 25, 2011 4:31 pm
Registered users
I took a different approach. I connected a Brultech sensor on every breaker in my box. Then went from room to room and turned things on and off watching the usage on my PC. I used a 500 watt halogen light to test the wall outlets.
I put a really small label on every switch and outlet with the breaker number for future
reference.
Top
Offline Profile
PostPosted: Tue Jul 10, 2012 8:21 am
Registered users
The Best way I have come across for outlets is a radio. Put it on and turn up the volume, when you hit the breaker with that outlet the radio goes off. Saves leg work for the lazy.
Top
Offline Profile
PostPosted: Mon Dec 09, 2013 4:40 pm
Registered users
I realize this is an old thread, but you do not need to shut breakers off to identify branch circuits when you have the right tools (~$20)...
http://www.amazon.com/Triplett-9650-Breaker-Sniff-It-Digital/dp/B0002THPOS/ref=sr_1_4?ie=UTF8&qid=1386625046&sr=8-4&keywords=breaker+finder
Top
Offline Profile
Who is online
Users browsing this forum: No registered users and 4 guests
Jump to:
