Pulse Output for water meter
Re: Pulse Output for water meter
Post by Teken » Sat Dec 28, 2013 11:21 am
I know this is a old thread but it goes to show you how long I have been researching into this project. :|
Can this device be used to monitor the water meter?
http://www.ebay.com/itm/Diffuse-photoel ... 27d086d9a9
If so, does it require any other parts such as a external power supply? If not, which pins on the GEM will this device be connected to?
Much Thanks
Post by ben » Thu Jan 02, 2014 1:29 pm
Teken wrote:I know this is a old thread but it goes to show you how long I have been researching into this project. :|
Much Thanks
It should with a little hacking, there's a diagram a page back that shows how to hook it up.
I think it requires an external power supply as per the diagram (N Type).
Post by Teken » Thu Jan 02, 2014 2:16 pm
Much Thanks
I will purchase one and report back. If it works this will be a great solution to monitor water flow. I will document the project for others to follow thanks for the feed back.
rnoble
Post by rnoble » Thu May 01, 2014 6:29 am
So I'm in the planning stages of installing a whole-house water filter system and am considering adding a water meter (after my utility meter) that I can connect to my GEM. Any reason this guy wouldn't work?
mwall
Post by mwall » Thu May 01, 2014 8:00 am
rnoble wrote:So I'm in the planning stages of installing a whole-house water filter system and am considering adding a water meter (after my utility meter) that I can connect to my GEM. Any reason this guy wouldn't work?
the water meters from ekm metering work very well with a GEM. so do their gas meters. fwiw, ekm has been a good vendor for us.
rnoble
Post by rnoble » Tue Jun 03, 2014 6:54 am
Thanks! I got the meter installed (as well as a whole-house water filtering system)... I'm getting pulses and can see the bar graph... Is there anyway to see the cumulative water usage with a DB? I was hoping the meter would help me know when to change my filter cartridges. Is this possible with SEG?
Post by ben » Tue Jun 03, 2014 10:21 am
The bar chart for daily/weekly/monthly/year should be cumulative on the DB (assuming you mean DashBox). The line graph will show flow.
rnoble
Post by rnoble » Tue Jun 03, 2014 10:24 am
Perfect. Thanks!
I found some good tools in SEG as well.
rnoble
Post by rnoble » Tue Jun 03, 2014 11:31 am
rnoble wrote:Perfect. Thanks!
Ben, could I be missing some modules? I don't have the bar chart module available on my dashbox. Below are my "Installed Modules"
Total Costs for Today
Main Panel Used Power
Line Graph
Day Compare
Watt Columns
kWh Column
Tabular View
Pie Chart
Cost Pie
Hourly Line Graph
Post by ben » Tue Jun 03, 2014 11:44 am
Line Graph
Day Compare
Watt Columns
kWh Column
Tabular View
Pie Chart
Cost Pie
Hourly Line Graph
Ahh I meant in the Loads section. Give kWh Column a try.
