Can't Get raw data to feed to Dashbox
Posted: Thu Dec 26, 2013 11:43 pm
by rhombixt
I have sucessfully installed my greeneye after patiently working through the manual. I however cannot seem to get the dashbox to read any data. When I check the raw feed, it says "no data". I have set the com2 port to be 115,200 as per the instructions, but I don't see any data comming from the port. Brultech is not responding to emails because of the holidays and this is my holiday project so I need some help please.
What am I missing to make this work? I am using the supplied cable wired corectly for a greeneye with ethernet module.
Re: Can't Get raw data to feed to Dashbox
Posted: Fri Dec 27, 2013 7:54 am
rhombixt wrote:Hello,
Please review the FAQ in this thread. At the very bottom there is a list of Questions & Answers to the most common problems.
Go through the list and report back success / failure: http://brultech.com/home/community/view ... 4630#p4630
Please kindly note that the GEM must be set to 19500 on COM 2, the Dash Box (DB) also must be set to 19500 baud on COM 2 as well.
Posted: Thu Jan 02, 2014 2:46 pm
Baud rates have to be set in 2 places, one is in the DashBox Settings section (under System->Baud Rates), the other is on the GEM itself.
Make sure your COM2 packet format is set to Bin-48-NET-Time when using the STS cable, that's the only packet format compatible the DashBox via STS.
Posted: Sat Jan 04, 2014 3:35 pm
by depasseg
And also remember to exit the GEM configuration page.
I've been using 115,200. I thought I saw it in a guide. Is that incorrect?
Posted: Mon Jan 06, 2014 4:03 pm
depasseg wrote:And also remember to exit the GEM configuration page.
We added 115,200 for COM2 on the GEM very recently. Its default is 19200 for Xbee module compatibility.
If you're using COM1, 115200 is suggested. On COM2, you can go either way.
Posted: Mon Jan 06, 2014 5:38 pm
by depasseg
Also, one other thing that's held me up was ensuring packet logging was enabled (it gets disabled after clearing data from the database). I had to re-enable packet logging in the Settings->System->Update Admin->Logging Settings.
