I've been running a GEM/Dashbox combo for years now and just recently added an ECOFlow Smart Home Panel and two Delta Pro batteries as backup and to run critical loads during peak rates. I just noticed today that when I switch the critical loads to run off of battery power (during peak rates) that the CTs read my solar input as switching directions.
My GEM/Dashbox are on a backed up circuit. Is it possible that I have it backed up on the opposite phase coming from the battery than it is when grid connected? I thought I had the grid/battery phases aligned but I could be wrong.
Could this be the problem?
Solar CT direction change when running battery
Re: Solar CT direction change when running battery
What channels make up that Net channel? Is it just the inverter?rnoble wrote: ↑Mon Aug 21, 2023 3:31 pmI've been running a GEM/Dashbox combo for years now and just recently added an ECOFlow Smart Home Panel and two Delta Pro batteries as backup and to run critical loads during peak rates. I just noticed today that when I switch the critical loads to run off of battery power (during peak rates) that the CTs read my solar input as switching directions.
