Dashbox with loading error
Brian C
Post by Brian C » Tue Sep 26, 2023 12:29 pm
Hello,
My dashbox seems to have stopped working with this in the upper cornerhttps://drive.google.com/file/d/1_w50Kr ... sp=sharing
I can access the GEM and see live datahttps://drive.google.com/file/d/1l9_3Wx ... sp=sharing
My dashbox shows https://drive.google.com/file/d/1LVdw5Q ... sp=sharing
https://drive.google.com/file/d/1pkyXhz ... sp=sharing
for some reason I cant get my pictures to show
I have tried
updating firmware
clearing memory
checking and changing com ports and data types
creating new SD card
installing backups with program to SD card
I can see with Utility
I tried communicating TCP/IP but I do not think my GEM is setup for that because I do not get the options shown in the manua
What is my next step?
Re: Dashbox with loading error
Post by ben » Tue Sep 26, 2023 12:36 pm
The issue is likely it can't resolve the time servers being used.
With the new F/W go into the Network settings and re-save your Ethernet settings and give it a reboot. There was a few older DashBoxes that need an update to their DNS resolution.
Wait about 5 minutes and see if that's resolved.
Brian C
Post by Brian C » Tue Sep 26, 2023 12:46 pm
I went to https://drive.google.com/file/d/13nl59S ... sp=sharing
and after a reboot I get the same thing
Post by ben » Tue Sep 26, 2023 2:24 pm
Email me your network settings so I can take a look.
What F/W is the DashBox on (footer)?
EDIT: See below first.
Post by ben » Tue Sep 26, 2023 2:27 pm
https://brultech.com/dashbox/dashbox_v4_2_4c17d.img
GIve this one a go, same thing after installed, go to Network->Ethernet, save settings.
Brian C
Post by Brian C » Tue Sep 26, 2023 3:00 pm
OK updated https://drive.google.com/file/d/1CIgzgD ... sp=sharing
Rebooted
waited 5 to 10 min loaded web page same thing.
My Gem# is still not showing up in the settings > energy monitors
It shows in Baud rate status.
I am getting this in the RAW Data loghttps://drive.google.com/file/d/1P32A5s ... sp=sharing
My time shows correct but normally I am UTC -6 .
Post by ben » Tue Sep 26, 2023 3:06 pm
Rebooted
What do you have under Settings->System->Admin Settings for time servers.
Brian C
Post by Brian C » Tue Sep 26, 2023 3:20 pm
Post by ben » Tue Sep 26, 2023 3:50 pm
https://drive.google.com/file/d/1HC0TYy ... sp=sharing dash system
https://drive.google.com/file/d/1LmqIvY ... sp=sharing GEM
https://drive.google.com/file/d/1LMvuyz ... sp=sharing dash time adjust
What format do the pictures have to be in to show with the Image function?
You should be able to attach and place in-line at the bottom of the post.
I have to leave soon so for now, set the DashBox to offline mode (Admin Settings) and set the time manually via the Time Adjust section.
Send me an email, if you're able to port forward I'll jump on it and fix it up manually tomorrow. I'll need access to port 9500 on the DashBox.
Brian C
Post by Brian C » Wed Sep 27, 2023 8:51 am
Sent email
