We've recently discovered a F/W issue with the GEM that occured in 5.35 to 5.38. The units affected are minimal, this COM F/W was only shipped between January 24th 2022 to February 2nd 2022.
There's no need to upgrade your GEM unit if you have an older COM F/W also. Since around COM 5.25 all the changes have to do with a 915Mhz RF module we're implementing to link remote GEMs to the DashBox.
The primary packet format sends the same byte repeated unless a secondary packet format is enabled.
This issue has been fixed in COM F/W 5.39
https://brultech.com/software/files/dow ... _5.39_.fmw
To load the firmware,
- Download the GEM Network Utility:https://brultech.com/software/files/dow ... _8.01_.exe
- Connect via TCP Client at the top.
- Click the Get GEM Info button.
- Click Select Firmware File and select the F/W file downloaded above.
- Click Start and let it run to 100%, you should see the SYS LED flash on the GEM while programming.
GreenEye Monitor COM F/W Issue 5.35 to 5.38
