A note here if you're upgrading from a version lesser than 2.35 and you get stuck on the password page.
The password page will always pop-up. The default password is nothing, you should be able to get just by hitting the button.
If blank doesn't work, you'll have to do the following procedure:
- Press the recessed PB switch at the bottom of the GEM and maintain it until the “SYS” LED turns yellow then release.
- The LED will flash “red” three times, then “green” three times, then “yellow” three times, press and release the switch when it flashes "yellow".
Upgrading to COM 2.35 forward - Password issues
