GEM at 480V line-line 277V line-neutral configuration
ECMBonilla
Post by ECMBonilla » Fri Jan 27, 2017 4:02 pm
I wish to buy a GEM. Ive read the 3 phase manual but i did not find a complete answer, so can you help me please? :)
Can i use GEM to measure that (3 phase at 480v)?
How can i do it (how energyce GEM)?
What i need?
Thanks, for helping...
Re: GEM at 480V line-line 277V line-neutral configuration
Post by ben » Fri Jan 27, 2017 4:16 pm
ECMBonilla wrote:I wish to buy a GEM. Ive read the 3 phase manual but i did not find a complete answer, so can you help me please? :)
What i need?
Our commercial version of the GEM is capable of monitoring 3-phase Wye systems. It requires a special configuration and a 3-phase kit. The 3-phase kit comes with a high-accuracy PT and phase detection pen.
Each GEM channel is only capable of monitoring 1-phase of a 3-phase system, meaning 1 3-phase load will take 3 GEM channels. So keep that in mind when speccing out a system.
Feel free to contact me via email for more information (ben(at)brultech.com).
ECMBonilla
Post by ECMBonilla » Fri Jan 27, 2017 5:22 pm
Then GEM can connect to 277 V line-neutral to be energized?
Do i have to ask for three phase kit before paying?
and
Do i have to buy a special software to configure GEM for 3 phase?
Thanks, for helping
Post by ben » Mon Jan 30, 2017 10:35 am
ECMBonilla wrote:Then GEM can connect to 277 V line-neutral to be energized?
and
Thanks, for helping
The GEM requires a standard 120V outlet to power it via a 5V wall supply. The 3-phase GEM has to have an additional module (PT) hooked up to a breaker in order to monitor voltage.
You have to ask for 3-phase as it requires an additional bundle.
All software compatible with the GEM is compatible with the 3-phase GEM.
ECMBonilla
Post by ECMBonilla » Tue Jan 31, 2017 11:21 pm
Manual says: Potential transformers will also be available with primary (line) voltage from 120VAC to 480VAC with an output signal in the 333mV to 666mV range.
I can not find it for buying, only the older 120V!, Is this included with standard package?? (i have been sending mails but no answer). Please aswer. Thanks
Post by Teken » Tue Jan 31, 2017 11:29 pm
ECMBonilla wrote:Manual says: Potential transformers will also be available with primary (line) voltage from 120VAC to 480VAC with an output signal in the 333mV to 666mV range.
You need only follow what Ben noted in the quote below in your email correspondence to the sales department.
Post by ben » Wed Feb 01, 2017 5:46 pm
All 3-phase packages have to be ordered through sales@brultech.com as they require special configuration, unfortunately there's a few of us out right now with the flu.
