Raspberry Pi BTMon.py Setup Guide
Post by ben » Fri Jun 24, 2016 11:38 am
BTMon.py Raspberry Pi Setup Guide
Updates:
2016-06-24: created initial guide.
This guide assumes a Raspberry Pi or other system is already setup and running EmonCMS. If you haven't previously setup a system, please start with the guide below.
viewtopic.php?f=40&t=1567
Required downloads
- PuTTy or equivalent SSH program http://www.chiark.greenend.org.uk/~sgtatham/putty/.
Installing BTMon
Steps:
NOTE: You may copy and paste the command line information from this guide into PuTTy.
1. Go to your home folder.
cd /home/pi
2. Download the latest version of BTMon.
sudo wget https://raw.githubusercontent.com/matthewwall/mtools/master/bin/btmon.py
3. Create a configuration file for BTMon, replace TOKEN with the API Key copied above and the NODE_NAME with whatever you want it labelled as. In this example, we'll be using BTMon in Server mode. Change device_type to ecm1240 is using an ECM-1240 and not a GEM.
Energy Monitor running as TCP Client
a. Copy/paste the following code. Change ip_port to whatever port the GEM is configured to send to.
printf "[source]\ndevice_type = gem\nip_read = true\nip_port = 8000\nip_mode = server\n[oem]\noem_out = true\noem_token = TOKEN\noem_url = http://localhost/emoncms/input/post.json\noem_node = NODE_NAME" > btmon.cfg
Energy Monitor using Serial-to-USB Cable
a. Download and install PySerial (this link may change, if below doesn't work check https://pypi.python.org/pypi/pyserial for a new link and replace the string following wget).
wget https://pypi.python.org/packages/3c/d8/a9fa247ca60b02b3bebbd61766b4f321393b57b13c53b18f6f62cf172c08/pyserial-3.1.1.tar.gz#md5=2f72100de3e410b36d575e12e82e9d27
sudo tar xvf pyserial-3.1.1.tar.gz
cd pyserial-3.1.1
sudo python setup.py install
cd ..
sudo rm -R pyserial*
b. Plug in the Serial-to-USB cable and find out how it's been assigned.
dmesg | grep -Eio "ttyUSB[0-9]+"
c. Take the value from above and run the command below, replace "ttyUSB#" with the value found above. Change serial baud to 19200 if using an ECM-1240.
printf "[source]\ndevice_type = gem\nserial_read = true\nserial_port = /dev/ttyUSB#\nserial_baud = 115200\n[oem]\noem_out = true\noem_token = TOKEN\noem_url = http://localhost/emoncms/input/post.json\noem_node = NODE_NAME" > btmon.cfg
4. Start BTMon to test.
sudo python btmon.py -c btmon.cfg --debug
Starting on boot
Steps
1. Run the following command.
sudo sed -i 's:exit 0:python /home/pi/btmon\.py -c /home/pi/btmon\.cfg \&\nexit 0:' /etc/rc.local
rora002
Re: Raspberry Pi BTMon.py Setup Guide
Post by rora002 » Sun Jul 10, 2016 2:52 pm
Hi Ben,
Thanks for your guide here. It has been very helpful. I have managed to get btmon.py running, and uploading data to emoncms.org.
I have set up btmon.py to start on boot, and so far this works fine for an hour, then stops. Is a log stored for the script somewhere that can help me find out what is going wrong?
Rob
mwall
Post by mwall » Mon Jul 11, 2016 8:16 am
rora002 wrote: I have set up btmon.py to start on boot, and so far this works fine for an hour, then stops. Is a log stored for the script somewhere that can help me find out what is going wrong?
rob,
is btmon still running?
run btmon in debug mode and dump the output to file:
sudo /home/pi/btmon.py -c /home/pi/btmon.cfg --debug > /var/tmp/btmon-out.txt
then you can look at the output to diagnose any problems.
m
Automan
Post by Automan » Sun Jun 25, 2017 10:08 am
I need more help trying to use my ECM-1240
I think Emoncms may have changed where it locates files or again it may just be being silly :)
I have the Emoncms webpage on my pi loading but it says
The log file has no write permissions or does not exists. To fix, log-on on shell and do:
touch /var/log/emoncms.log
chmod 666 /var/log/emoncms.log
Edit: Solution easy, if one has a brain :)
Just run the two commands with sudo in front so they are run with root user privleges
sudo touch /var/log/emoncms.log
sudo chmod 666 /var/log/emoncms.log
Automan
Post by Automan » Sun Jun 25, 2017 3:57 pm
Made some more progress...
In this thread it has
Code:
Then later
Code:
So the first btmon.cfg is deleted and replaced by the later one with some of the information missing.
Merged the two together and it sort of works.
