How to see peak loads over a long period?
TonyPh12345
Re: How to see peak loads over a long period?
Post by TonyPh12345 » Mon Aug 22, 2022 6:43 pm
Just updated to 4c13. The data looks correct now (and is hinting August is going to be a dismal consumption month), though the titling is still missing.
Thanks for your work, Ben!
bgrubb1
Post by bgrubb1 » Tue Aug 23, 2022 12:33 pm
I loaded C13 and concur, hour data looks correct.
Is half hour possible ? Dont see it in the release
...Barry
Post by ben » Wed Aug 24, 2022 10:14 am
...Barry
Half hour isn't in the release, it's possible via query but I'm not sure if it'll be possible to chart it monthly as you'd need to comb thru a month of minute data. Messing around with it a bit.
I'll see if I can code it into an export function for now.
Post by ben » Fri Aug 26, 2022 11:06 am
Appended an export function into 4.2.4c13
http://brultech.com/software/files/down ... 2_4c13.img
http://dashbox-ip/index.php/pages/export/exportMonthlyMaxWatt/channel_id/date/type
- Channel ID can be gotten from the Channels page, it'll be in your address bar under "c1="
- Date is Year-Month, 2022-08 for example for this month.
- Type is either 0 - Every Minite, 1 - Every Hour, 2 - Every Half Hour
The end link will look something like:
http://192.168.2.80/index.php/pages/export/exportMonthlyMaxWatt/1558/2022-08/2
bgrubb1
Post by bgrubb1 » Fri Aug 26, 2022 4:49 pm
I am getting "invalid file type" when I attempt to install
...Barry
Post by ben » Mon Aug 29, 2022 9:15 am
...Barry
What F/W are you currently running? If you're still at a19 you need to install the 4.2.4b updater then install it.
bgrubb1
Post by bgrubb1 » Mon Aug 29, 2022 7:00 pm
i am an 4C13
the download link you provided in the forum doesnt work
I tried re-downloading from the software site and file is slightly bigger than original 4c13 but errors out
Post by ben » Tue Aug 30, 2022 10:37 am
i am an 4C13
I re-uploaded as 4.2.4c14 as Microsoft Defender was false-flagging it.
EFIUnlimited
Post by EFIUnlimited » Sat Apr 29, 2023 7:50 pm
I am looking to find peak load, but I want to apply it to a group vs. an actual channel, and that seems to be broken.
My use case is similar to the OP, the difference is, I am looking to install backup power only for select 'critical load' circuits, not the entire panel. I want to know the peak usage of these critical circuits before I rearrange my breaker panels.
A 'nice to have' would be to find peak amps too for breaker sizing. I don't have too many reactive loads, so I can use peak watts to approximate peak amps, but an actual measurement I can use would be nice. I do remember seeing VA somewhere as an available unit, and this could work, but I don't remember where that was.
Brian
