It looks like there's topic retain flags and client retain flags. The topic-level retain flags should be on.
MQTT
Re: MQTT
Looks like I was wrong, retain is correctly set, I just didn't understand the way that MQTT Explorer shows whether a value is retained or not... it will only show retained/not retained until it gets a new value, so I have to pause the client immediately after connecting to see what is retained.
Re: MQTT
Some of the kwh numbers don't seem to make a lot of sense though...
For my channel 26, total for the day is 0.775 kWh, total since I turned on MQTT transmittal (since it appears to start at 0, not to send the currently stored kWh?) is about 0.529kWh, and the kwh topic for c26 has had 0.002 kwh and 100-150 watts in it all morning
Re: MQTT
The DashBox is sending the kWh, Watts, and Amperage used each minute.vilord wrote: ↑Tue Dec 27, 2022 1:18 pmSome of the kwh numbers don't seem to make a lot of sense though...
Re: MQTT
I built a small esp8266-based GEM to MQTT ESPHome interface that will plug into the XBee slot and post the GEM's cumulative wattsecond meters as watthours here: https://github.com/jcam/gem-mqtt-esphome
This doesn't rely on the dashbox, so would work without it.
Re: MQTT
Might be worth making a new thread about this, I'm sure there'd be some interest.vilord wrote: ↑Wed Dec 28, 2022 10:21 amI built a small esp8266-based GEM to MQTT ESPHome interface that will plug into the XBee slot and post the GEM's cumulative wattsecond meters as watthours here: https://github.com/jcam/gem-mqtt-esphome
Re: MQTT
Ben any chance to get the Dashbox to publish MQTT topics more often?
Re: MQTT
What are you using MQTT with? Packet forwarding has been improved and will send every packet to whatever host you're using.ColoradoSolar wrote: ↑Tue Nov 07, 2023 12:18 pmBen any chance to get the Dashbox to publish MQTT topics more often?
You could have it fire to a btmon.py script and have it convert MQTT with every packet.
Re: MQTT
I am using the data is an app I wrote that I use for controlling my solar system. I went the MQTT route since it seemed the easiest and it works fine just the updates are not quick enough. Where is there some docs on packet forwarding, including the format of the packets?
I found the packet format doc. Another question. One of my GEMs is connected RS-232 to the dashbox and the other is through WiFi. Can I still use packet forwarding?
Eric
Eric
