MQTT Channels are crossed up
jkosharek
Post by jkosharek » Sun Nov 19, 2023 6:23 pm
Ben, playing with MQTT to get data from Dashbox to HA or maybe to EISY/IoX/PG3x and noticed that some of the channels are crossed up.
C1 name is pulling from what should be in T1 and T1 isn't pulling a name
V33 name is going to C33
The instructions on the 'MQTT Publisher\MQTT Publisher Steps' for #3 seems like it needs to be deleted because the menu to select channels is not there, or there is a bug that isn't displaying the MQTT settings I saw in someone else's screen shots.
Can the frequency be configured for how often topics are published or set to publish on any value change?
Screenshot 2023-11-19 at 5.59.36 PM.png (299.25 KiB) Viewed 5986 times
jkosharek
Re: MQTT Channels are crossed up
Post by jkosharek » Mon Nov 20, 2023 9:14 am
Ben, also can the MQTT be configured to send the info in JSON format?
Post by ben » Tue Nov 21, 2023 11:52 am
Frequency is not controllable, mixing a bunch of options was causing some conflict with data logging on the DashBox.
I suggest using packet forwarding and btmon.py if you want full control over frequency so the DashBox is just dumping the packet.
Not currently.
jkosharek
Post by jkosharek » Tue Nov 21, 2023 3:56 pm
Not currently.
Will the MQTT topic channels/values being mixed be addressed?
So the btmon.py setup would be another Packet Forward in the Dashbox, any current setup info on btmon.py with dashbox?
Post by ben » Fri Nov 24, 2023 1:25 pm
Not currently.
Looking into the ordering thru the DashBox. Added some sorting to the query but it's still a little weird.
Based on the btmon.py documentation it looks like you get this by default:
the voltage of the system:
<base_topic> /volts -> <volts-value>
for each energy channel:
<base_topic> /ch <channel-n> _w -> <power-value>
<base_topic> /ch <channel-n> _wh -> <energy-value>
<base_topic> /ch <channel-n> _dwh -> <delta-energy-value>
for each temperature channel:
<base_topic> /t <temperature-n> -> <temperature-value>
for each pulse channel:
<base_topic> /p <pulse-n> -> <pulse-count>
Or you can map what you want to be sent.
