Load Shedding
iplay1515
Load Shedding
Post by iplay1515 » Sat Feb 25, 2012 1:32 pm
Does anyone have an interest in working on a joint project to selectively turn on/off loads based on Brultech data?
vitaliy_kh
Re: Load Shedding
Post by vitaliy_kh » Sun Feb 26, 2012 9:25 pm
Assuming all your loads of interest are controlled by Insteon relay/dimmers and you have
Insteon ISY-99i Controller from Universal Devices you can use input from ECM1240(s)
(as well as many other sensors) and control your loads in real time as we speak.
- Vitaliy
topherhansen
Re: Load Shedding
Post by topherhansen » Thu Jan 23, 2014 5:04 pm
One day I want to figure out how to do this.
I have the green eye with ethernet, and I don't think the isy99i brultech program works with anything other than the zigbee option. At least that's the case a year or two ago when I got both of them.
Any idea if that changed?
Re: Load Shedding
Post by ben » Fri Jan 24, 2014 11:20 am
topherhansen wrote:One day I want to figure out how to do this.
The GEM only works with the ISY-994iZ via Zigbee correct. The ISY-99i is compatible with 1 ECM-1240 via TCP/IP with the Energy Monitoring module if I remember correctly.
bgrubb1
Re: Load Shedding
Post by bgrubb1 » Fri Jan 24, 2014 1:01 pm
I am using a Vera 3 instead of the ISY, talks TCP/IP to the GEM and controls via ZWave instead of Insteon
