ECM 1240 installation inside enclosure
jfisher
Post by jfisher » Wed Jul 07, 2010 6:18 pm
I am working on a project which requires concealing the ECM 1240 inside a PVC electrical enclosure. My original plan was to put an outlet for the power supply, as well as the ECM 1240 inside the enclosure. We will be monitoring remotely and do not want the device to be unplugged, so ideally we would have everything inside an enclosure. However, I read that the ECM 1240 should not be installed inside an electrical panel with potential high voltages. Does this plan to install an outlet into the same enclosure fall into this category? Would I have to do two enclosures, and if so how far apart must they be?
paulb
Re: ECM 1240 installation inside enclosure
Post by paulb » Thu Jul 08, 2010 11:01 am
There is no problem if the electrician installs a standard electrical outlet (according to your local electrical code) in the enclosure.
jfisher
Post by jfisher » Mon Jul 12, 2010 1:42 pm
Great news, Thanks!
2ts
Post by 2ts » Fri Aug 13, 2010 2:52 pm
I have three installed inside a 24 x8x8 gutter i had to move power supplies to top because it was getting too hot.
