Last visit was: It is currently Wed Jun 19, 2013 11:23 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3, 4, 5
Author Message
 Post subject: Re: ECM-1240 counter questions
PostPosted: Wed Aug 04, 2010 10:05 pm
Looks like you have a valid pulse going to the input of the divider (pin1). I would suspect that power supply noise might be causing problems. Do you have any capacitors at your disposal? Something in the range of 10uF to 100 uF? If so, try installing it between pin 7 and pin 14 (Vdd & Gnd) of the IC ..... remember to observe the polarity of the capacitor.
If you do not have a capacitor, then I would suggest using three 1.5V batteries in series as your power source.
Top
Offline Profile
PostPosted: Wed Aug 04, 2010 10:29 pm
I will give those ideas a try.
Are you saying replace the .1uF cap that is currently between pin 7 and 14 with a 10uF or 100uF cap? Does it matter what kind? Your original diagram said to use a ceramic capacitor but I was only able to find a multi-layer ceramic cap. Does that make any difference? Also, I couldn't find any polarity indicator on the .1uF caps I have.
Ira
Top
Offline Profile
PostPosted: Thu Aug 05, 2010 12:00 am
Leave the current .1uF in the circuit. There is no polarity on those caps. The large cap values are polarized.
Top
Offline Profile
Who is online
Jump to:
