This is what my GEM UI looks like. It doesn't look like UI in my manual.
Also, I'm not able to access port :8000 on the unit, but I am able to access port :80
When I try to access the unit via the network utility, I am able to connect to it, but when I click on the "Get GEM Info" button, I get this error.
I recently (August) bought the unit from Brultech. Do I have an old firmware or is there newer documentation or a tutorial on how I can get set-up? I just want to be able to view the Live Data from my laptop. Thanks!
Has the GEM UI changed? Running into issues with Network Utility
- Screenshot 2023-09-27 at 9.54.08 AM.png (869.71 KiB) Viewed 23989 times
- Screenshot 2023-09-27 at 9.53.47 AM.png (801.19 KiB) Viewed 23989 times
- Screenshot 2023-09-27 at 9.51.48 AM.png (1.27 MiB) Viewed 23989 times
Re: Has the GEM UI changed? Running into issues with Network Utility
Sent you a couple emails, let me know if your received them.
There may be a bug in recent F/W where COM1 gets stuck at 19200 baud. Fix is to go into Application Settings and change it to 19200, go into the GEM Setup Webpage after and set the baud to 115200. Refresh the page, if it didn't work try to set it again then click the Reboot COM button. At this point the page shouldn't work anymore, go into the Application Settings and set it back to 115200.
